Diamond Audio CM3
  • 1
sbddvm
I have two 10" Diamond Audio CM3 subs that I am putting in a F-150.
I can get around 0.75-1.0 cu. ft. per sub.
Their specs show sealed inclosure to be 0.5-1.0 cu. ft. and ported inclosure 0.75 cu. ft. per sub.
http://www.diamondaudio.com/Files/products/CM3%5Fspec%5Frev1%2Epdf
Any of you have experience with these subs? Port or not to port?
Also, since the box will not be deep enough to port on the same side as sub should I port out the top or side of the box?
Let me be a little more specific. I'll start from the beginning.
Equipment:
Ford SVT Lightning (regular F150 cab)
Two 10 " Diamond Audio CM3 subs
PG 1200.1 to push them
AudioControl 4XS crossover (w/ subsonic filter)
PPI PAR-245 preamp eq
Two layers of RAAMmat60 all around
I know that choosing between sealed and ported enclosures comes down to personal preference. I don't necessarily need super SPL, but I do like my bass. Basically my concerns boil down to this.
1) will these particular subs perform better in a sealed or ported enclosure, in this truck because of limited space.
2) since I have plenty of power, would I be better off with sealed
3) will a sealed enclosure give me the bass I like?
BTW
These subs are designed for small enclosures. Also, there is no way I can get 3-4 ft3. Maybe 2 ft3 at the most.
I had some of theyre subs and components in the past in the late 90s. They were nothing special and were expensive. I had better luck with Bostons...
These have been used for a few months and then were pulled for pro drivers to take their place for more output. These are 4 ohm drivers and in...
38
848
The siq amps are Sq beast as well. And much cheaper. Made by s&I in Korea iirc
251
sbddvm
sbddvm
Ft. Lauderdale
sbddvm
    May 12, 2024
Brendon Jenness
    May 11, 2024
