Sold Diamond Audio 6.5in Xovers
BassAddictJ
had these for a while but decided to go with some memphis Xovers. these were made about 8 years ago in germany, part of the m5 6.5inch component set. has outputs for not only tweet and woofer, but also an RAF (rear acoustic fill) which i found very helpful. i hooked some tweets to the RAF with some inline oxovers on them (RAF is full range iirc) and they sounded better off the RAF than they did off deck power.
only thing is the tweeter output is ment for an 8ohm tweet. itll work with a 4ohm tweet but if u blast it way too loud, the tweets will go quiet, then come right back on when u turn the volume down a bit. i think this is some kind of a protection circuit (which is pretty cool cause most xovers have a fuse or just blow up). typically youll get a feel for whats too loud or not for them and can easily find a good high volume spot tha wont kick them into protect. it only does that on heavy treble (ussually heavy metal). RARELY does it do that on most rap. great units, never let me down.
22 shipped.
also i have an M3 6.5 xover. one of them got water damage so i took outthe other one and its been sitting in my cloet for some time now. also ment for 6.5's. also has the RAF. this one is ment for a 4ohm tweet. its cover is a lil loose but a piece of tape on it anywhere will hold it in place.
12 shipped
yahoomail is acting weird so ill get a pic of the M3 Xover as soon as i can, but its in same good condition
all of these Xovers are programable and u can adjust your tweets dB level.
the M5's have it -2, 0, and +2 dB.
the M3 has it referance(0), and -2dB
lol no problem. the M5's are M56.1x....M3's is M36.1x
srr fr the lack o hlp, iv just been busy as hell and dont wana do the legwork lol. good luck man
BassAddictJ
BassAddictJ
FL
BassAddictJ
