diamomd audio
I wouldn't mismatch tweeters and mid's unless it's diamond audio tweeters. May run into some problem's with the different ohm loads and the crossover. But it's up to you. I would suggest look on ebay for the mounting equipment for whatever size tweeters you have.
You could call Diamond and ask them to send you some flush mounts? It might cost 5 dollars //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif.
Your the consumer, Customer Support was designed for you.
I would say over 80% of passive crossovers out there all use the same configuration, 3khz is somehow the magic number. Even if it was off a bit, you should be okay, as long as you're not stupid enough to bottom out the crap out of it. Change 'em if they have matching impedances.
BloodyGuts335i
Team DC
BloodyGuts335i
Morris County NJ
xreymax
vegang
vegang
