Diablo Audio Tech HF2500.1
infamous_e46
hArRy_DaNgLeRs
Fresh from authorized tech repair
used
485 shipped obo
this amp never went up in smoke or got all toasty it would power on but no sound an amp repai man local to kingsuv that has been going thru all the blown amps repaired and replaced all the overrated parts in the amp
clamped at 2650w peak at 2ohm
Testing Conditions were as follows
Power supply: 14.4 VDC power supply
Test signal: 50hz sine wave
Load: Dummy Resistor load
Environment: 77 Degrees F free air
Instrument: Audio Precision Sys1
S/N Ratio - 95.2db
Input Level - .133Vrms to 7.5Vrms
Total Harmonic Distortion /Power Chart
Power output @ 4ohms
Power Output @ 2ohms
Power Output @1ohm
Frequency response testing
-3db Frequency response = 8Hz~179Hz
-1db Frequency response = 11Hz~136Hz
Frequency Response
Low Pass Frequency Response
Subsonic Filter Response
Overload Protection:
Unit Protects at less than 0.65ohm at full output power
Thermally at 82 Degrees Celsius
Voltage: 7.7V
S/N Ratio - 95.2db
Power Output @1ohm
Frequency Response
Voltage: 7.7V
yep
infamous_e46
hArRy_DaNgLeRs
infamous_e46
California
infamous_e46
