xluben
I just modeled the JL 10W7 in 1.5 cu ft @ 32 Hz (with 9" x 1.5" port) and got just over 35 m/s for the air velocity!Air velocity graph shows how fast air mass travels in port. In order to keep chuffing noise low, you should limit the peak velocity at 5% of velocity of sound, or about 17 m/s. Like the cone excursion graph, the desired powerlevel is set also by same watts setting. Note that if air velocity peaks exceeds previously mentioned level.
You'll need more like 9" x 3" (or ~25+ sq in of port).
