Subwoofer/speaker brand:Sundown Audio
Subwoofer/speaker model, size, and number of woofers:6 SA-15s
Vehicle enclosure will be used in (please add notes if specific or unusual placement will be used):85 Chevy Suburban. No wall, behind second row
Max dimensions (MUST fit in vehicle or through trunk opening!):48w, 52d, 25h (can go taller if needed)
Amp or expected power handling:2 AQ3500.1s
Listening expectations (description):Loud/low. Hairtrick is a plus
What bandwidth is acceptable? 35-60hz high output, 30-80hz? Ignore if you do not understand25-60hz
How low do you want it to play and how important are the low notes (Song examples are encouraged)?The low note in "Put on" is acceptable. I'm not a number chaser
Are you looking for a heavy low end, or one that blends with the rest of the output?Semi-heavy
How important is sound quality compared to loudness? Louder the better
Enclosure type request (Are you looking for a vented or bandpass for any specific reason)?Vented
Any specific enclosure preferences (Double baffled, flush mount, center slot, blowthrough, home environment etc)?Double baffle, flush mount. Sub/port up is probably my only option, but I'd like to do port back if possible. Aeros are always an option, if they will help. I can get 10-12" sono-tubes from lowes and flare them
Other notes:
Other notes:
