deisgn for 12" SPL
kyleorsini
just got a mach 5 spl thanks to mark //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif and i need a design done up max height is 15" and width 38 max. depth would be the variable.
i want it 3 cubes at 36hz, double baffle (flush mount). need some braces inside the box and some angle pieces for the corner. thankss //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
The box I designed for you to Mach 5 specs wasn't what you were looking for? I kinda thought their box was a bit too small and tuned too low. Refresh me what the specs were, I think around like 28Hz or something with only 2 cubes.
EDIT: Actually, I was looking at the specs, SPL 12 is 3 cubes @ 36Hz. Did you have an IXL 12 before?
Keep in mind, you're running TWO AQ220D's so you need to have a small box for the mechanical power handling aspect. Also, that's a rather high tune for a daily setup. 3 cu. @ 36 per recommended by Mach 5 would sound like a much more reasonable setup for some str33tb3atz.
Bah...i could play anything ...30hz and all. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I still say 2cu - 2.5cu for biggest.
nick i did have a ixl before, and the box you did up for me sounded great after i got a woofer that worked and after i got it and after other problems mark graciously upped me to a SPL.
i will be running this at 1ohm with my orion 2500D so 2400rms. for daily use. currently i have it wired to 4 ohm (1200rms) untill i can get my amp set properly and its in the 1.8@33 hz box u did for me nick and its awsome. im doing 3 cubes at 36hz cuz thats what marks recomended. if people have used it and think i should do something different chime in. id like to be doing this box tomorow night if possible //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
yess im aware, im looking for some more. mark gave me some port dimensions for the box dimensions i gave him so im thinking of that just wanna see some more.
I had mine in about 2 cubes, and had two 3000d's @ 1 ohm strapped on it. 149 dB at the head rest @ 45 hz //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i currently have puggsley doing a design for me when he has
some free time so im goood now //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
thxx mark, like i said ones being designed up for me now but i have one already from another forum if someone wants to check it see if its good then ill just stick with that //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
2.2 cubic feet tuned @ 38.5hz
Cut Sheet:
Top - 30"x15.75"
Bottom - 30"x15.75"
L Side - 15"x12.5"
R Side - 13.5"x12.5"
Front - 26.75"x12.5" (2x)
Back - 30"x12.5"
Port 1 - 11"x12.5"
Port 2 - 6.5"x12.5"
45 angles - 3"x12.5"
kyleorsini
kyleorsini
winnipeg,mb
kyleorsini
    Jun 20, 2026
    Jun 20, 2026
