Polar
With having 2 amps is it beneficial or even possible to go 3 way active? Should I just run it standard for now?
I'm trying to learn as much as I can about running active, so please forgive my ignorance. I have the 80prs as well, and am in the process of acquiring the components for my install. Why does one need 5 separate channels to run active, considering the head unit only has three channels for output, running passive or active.You'd want to have 5 amplifier channels, although I think you could run a pair of tweeters off the internal amplifier on this head unit. You also obviously need a pair of mid-woofers and a pair of tweeters to have something to run active.
Ah, now I see, 5 channels, as in sub, mid left mid right, high left high right.If one of your amps is a 4ch it will work
Thats correct....I run active setups in several of my vehicles...A much cleaner and detailed soundAh, now I see, 5 channels, as in sub, mid left mid right, high left high right.
Thanks for clearing that up!
