Definitive: Cold weather = lower output
X2 I'm pretty tough on my stuff when its cold too, just let it warm up a little bit and let er rip!!!
See the quote below.
Zaph did a study on this and his results were very conclusive and consistent to the OP's.
http://zaphaudio.com/temp.html
Zaph is very respected among the DIY community and his study shows that at 0 degrees, his woofer in review has almost zero output below 200hz, whereas 110 degrees plays the lows with authority.
should be louder in the cold, i have done cold weather test using refrigeration, granted it was in a room not a car so there may be other factors such as the amp or car battery, but bottom line is colder air means colder wire temperature which means lower resistance if the wire is aluminum or copper which means higher sensitivity and more SPL over a large portion of the range of your system. - run-on-sentence.....
you should read the techy articles in this thread.....and do realize that the "cold" these guys are talking about is sub 0
retry your testing in a deep freezer instead of a fridge and be sure to set a woofer in the deep freeze overnight before doing any testing
That's just ignorant.. The reduction in resistance doesn't have ANYTHING to do with the lower output - but rather the T/S parameters of the speaker itself changing.
At 0 degrees, Zaph cannot calculate T/S parameters for that speaker at 0 degrees because there is NO impedance peak. Resulting in ZERO bass output below 200 Hz.
Currently -20 at the moment, just about to leave for classes.
The sub is a BLOCK of ice. I wont be listening to music for a LONG time it seems.
When it gets warmer though i will post up some videos of my RSDC. I love the thing. I only have 1 and it hits EXTREMELY hard!
So since this guys test is accurate, then im really not hearing my sub play below 200hz? My ears must be playing tricks on me.
you are a douche.....don't read into what is stated above....
this thread is about when a coil is very cold....like sub 0 temps.
as soon as you start to play the woofer, it will gain temp and begin to play more normally. What 'that' guy is stating is that when the temp continues to drop below (some temp which I don't know) then the driver's ability to play frequencies below 200hz is hindered.
Now do I believe this? maybe, but I would have to see it for myself:cool:
I dont understand how this DOESN'T make sense to you guys
If in fact it were -50 F outside and it stayed at that temperature for a moderate amount of time (6hrs or more) the sub would simply be unable to perform because it would literally be slightly frozen.
The rubber surround would be HARD as a rock and you would be hard pressed to move it..
Why don't you try this out for a test..
Take some 12ga wire and leave it outside for 2 hours when its 0 or below. you pick that wire up and tell me it is malleable..
Same principal for the sub, since the rubber is stiff the cone wont have any excursion, thus just building up heat in the coil.
The test shown before wasn't talking about the COIL, he was talking about the CONE and surround..
Think about it.. How much excursion is needed for 200hz??? Not much but try to do 40hz or 50hz, much much more is needed and since the cone can barely move the cutoff is a cliffhanger at 200hz.
microhaxo
microhaxo
MINNESOTA
John_E_Janowitz
