decent bump?
You can only bridge it at 4 or 8 ohms.If the sub is dual 4 you can bridge the amp at 8 ohms and get basically half the power of the 560.
Or you could wire one voice coil per channel, but I doubt those 4 ohm ratings are anywhere near accurate.Either way you'll get anywhere from 200-350 to it.Not too bad I suppose.
And yes, it should add a good bit of bass to your music.
puregunpoore06
puregunpoore06
beaumont tx
puregunpoore06
