youdoofus
Skibidi
thoughts on fatmat. I found it for a pretty good price for a small amount with a cutter and roller. Is this stuff any good?
Her some story’s of it not staying glued down but imho that’s probably due to not cleaning and prepping before sticking it down. I have never used it myself , how thick is it ?thoughts on fatmat. I found it for a pretty good price for a small amount with a cutter and roller. Is this stuff any good?
it says 50 mil on the site. I figured its worth a shot at $17 shipped for 5 sq ft with a roller and cutter.Her some story’s of it not staying glued down but imho that’s probably due to not cleaning and prepping before sticking it down. I have never used it myself , how thick is it ?
Ive had 3 layers of 80mil. on for approx 4 years now.. Cleaned everything with Alcolhol..spot spray paint any exposed bolts or nuts..silicone any exposed joints.Spot sprayed those also.Placed first layer with using heat gun and second and third.Just hot enough that it will stick and roll, nicely/not melted.Any cavity areas that are used for replacement parts such as doors..3/8" ABS plastic with self tapping 5/16"-1/2" screws and sealed around with silicone.Never had any issuesthoughts on fatmat. I found it for a pretty good price for a small amount with a cutter and roller. Is this stuff any good?
Where’d you get the plastic?Ive had 3 layers of 80mil. on for approx 4 years now.. Cleaned everything with Alcolhol..spot spray paint any exposed bolts or nuts..silicone any exposed joints.Spot sprayed those also.Placed first layer with using heat gun and second and third.Just hot enough that it will stick and roll, nicely/not melted.Any cavity areas that are used for replacement parts such as doors..3/8" ABS plastic with self tapping 5/16"-1/2" screws and sealed around with silicone.Never had any issues
All over the Bay..Some places have several sheets in bulk or you can even find a single 4x8 sheet, even Plexy, and determine what thickness you want/looking for and sizeWhere’d you get the plastic?
Sent from my iPad using Tapatalk
wel geez!! with that level of effort i wouldnt even begin to think that youd have any issues with it!!Ive had 3 layers of 80mil. on for approx 4 years now.. Cleaned everything with Alcolhol..spot spray paint any exposed bolts or nuts..silicone any exposed joints.Spot sprayed those also.Placed first layer with using heat gun and second and third.Just hot enough that it will stick and roll, nicely/not melted.Any cavity areas that are used for replacement parts such as doors..3/8" ABS plastic with self tapping 5/16"-1/2" screws and sealed around with silicone.Never had any issues
