ddm reading
cbuts
so i checked with my ddm on my system
playing a -3db beat at volume 39/50 ,
my amp is reading like 50.4 volts,
and when im playing songs, its ranging from 20-45 volts. ..
is this okay for a rockford fosgate 1500 1bd and 2 sa 12s? or am i overpowering them?
the gain is about 5, infrasonic filter on, ported box.
d4s wired to 1ohm
4awg, 100A fuse(atm) upgrading to 0awg later.
it sounds just fine.. my voltage on my battery is stayin above 12.4 aswell.
but is this bad for my subs?
thanks!
So a 1ohm final load. 50.4 volts * 50.4 volts= 2540.16w @ 1ohm. So if it was seeing a true 1 ohm load them you are probably clipping, but its hard to tell without knowing the actual final load. I am still a noob though so I would wait for someone with a little more experience chimes in.
subs clipping, or amp clipping? i dont hear anything?
You are not seeing a drop because of clipping, but because each frequency has its own power level, thus measuring voltage when a song is playing, you will see it jump all over the place. But going back to what was said about setting voltage to 1500@1 around 38V, this is a good response and is acceptably accurate. But you cannot judge voltage on multiple frequencies, like a song, because again it will jump. But this is not due to voltage drop, but recording capabilities of the -3dB tone vs the recording of the song, which can vary upon each song if they are from multiple sources. So, you will likely always see a lower voltage from a test tone to a song, because of the recording quality and output when played. If a song is copied multiple times, if not digitally, to retain quality, this will effect voltage as well.
So, go with the idea given of 38V setting with a test tone, and disregard the changing voltage of a song...this is normal.
so bring the 50.4 volts down to 38? thats going to be a huge difference, are you sure i cant go any higher with this setup?
and what does "clipping" do? because it sounds awesome.. .lol //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif its not gonna sound nearly as loud at 38v.
do i need to find someone 1 with one of those things to check for clipping? i think they're dam expensive arent they, how would i even use that on my subs?
how do i get them like these???
lol
you cant set gains using music because it changes constantly. you're supposed to be using a 50hz tone to set your sub gains
VERY TRUE. Great point!
But as far as using a 50Hz test tone, this is something I am doing a video on soon that will disprove the standard 50Hz tone rule. It will be based on excursion control and impedance changes rather than a standard. Ill hopefully have it up soon, within the month, so things like this are avoided.
Your volts should be set around 38 for 1500 watts @ 1 ohm with a 0 db tone. If you set your gain with a -3 db tone and play any music thats 0 db, you'll most likey clip the **** out of your subs.
yep i have mine on my t15001bdcps set to 38.6 on both.
cbuts
cbuts
canada,ont
cbuts
vegang
vegang
