mike49504
To fix that amp i would charge $100.00 plus shipping. The z1's have parts in them that can get expensive if not repaired properly the first time. For example you have a blown output ,and shorted power supply fets and you only replace the power supply fets in the amp and leave the blown output transistor. Which in return it will blow the power supply all over again and could cause extensive damage to other components inside the amp making it unrepairable. Or the cost would be the same to repair the amp at that point as buying a new one. Chris at db-r probably would agree with me that if you dont have knowlege of fixing this type of amp dont attempt to repair it yourself . Not trying to downgrade anyone on here but the z1's sometimes have hidden problems and if you dont catch it the first time you repair the amp it can get very costly in the long run or your stuck with a paper weight .
