tjjohnson91
well hooked my other subs up the other day to .5ohm and it jammed tuned it and all..... then i turned it on to show some people and worked good for a 1 min and bamm it turned off,(WTF) i turned it down and the amp turned on..... my volts didn't drop lower then 13 at idle..... so i wired it to 2 ohm thinking its being a ***** and bamm it started doing it there too
it will play perfect then turn off and then when ever it wants itll turn on again
*the remote is reading 14 when the car is one*
*ground has not changed *
*its wired to 2ohm*
something blown on the inside?
*its wired to 2ohm*
