DD subs are peaky and don't get low?
LosIsATool
I keep hearing that statement. 4 cubes net tuned at 33hz
Quick TL numbers
27hz- 148.8
28hz- 148.8
29hz- 148.9
30hz- 148.9
31hz- 149
32hz- 149.1
33hz- 149.1
34hz- 149.2
35hz- 149.3
36hz- 149.3
37hz- 149.3
38hz- 149.2
39hz- 149.1
40hz- 149
45hz- 148
Equipment is in sig. Looks peaky to me and not very low.
Quick TL numbers
27hz- 148.8
28hz- 148.8
29hz- 148.9
30hz- 148.9
31hz- 149
32hz- 149.1
33hz- 149.1
34hz- 149.2
35hz- 149.3
36hz- 149.3
37hz- 149.3
38hz- 149.2
39hz- 149.1
40hz- 149
45hz- 148
I hear ya ..thats what im goin for 48-49 in high 20s- low 30s ..if i crack a 50 so be it..
just like pretty much anything, it is pretty much all box dependent. Response looks super flat, good job.
aside from box design, copper v. aluminum coil and ferrite v. neo i think have a decent deal with if a sub is "peaky" or not. not 100% sure on that though.
Only thing I know is dd subs definitely like larger boxes one 12 in a 3.25 box tuned 32 is nasty and plays fairly flat.
The new i models dont need a huge box. DD is saying you can run 3 12s in 5 cubes now. I'm not reaching full xmax now but I do plan on adding a bit more power.
Quick TL numbers
27hz- 148.8
28hz- 148.8
29hz- 148.9
30hz- 148.9
31hz- 149
32hz- 149.1
33hz- 149.1
34hz- 149.2
35hz- 149.3
36hz- 149.3
37hz- 149.3
38hz- 149.2
39hz- 149.1
40hz- 149
45hz- 148
New basket woofers ? The new ones with the new suspension will be ALOT smoother than the old style drivers; which is where the generalization came from. In terms of music the new platforms are a massive step up.
Yes they are. Way lower fs then prior models. You can still get the stiff suspension pack and raise it.
It was an h series so maybe its changed doubt it though as far as dd recommending a box I wouldn't trust a word out of their mouth.
A freind is running a "DD box" doing a 149.9 with a single 9518 on 2400 rated watts on basically stock electrical. It may not work for every install but its working for his.
LosIsATool
LosIsATool
Pensacola, Florida
T3mpest
