DD M3 amplifier?
I would do it they put some power out at a lower ohm but if your running 1 or 2 ohm load I would stick with the 2500 anything lower then that I would go with the DDM3
Yeah my 10' RE XXX's are dual 2's so I need power at two oms. Do you know the wattage of the DD M3 at 2 ohms ?
Thanks
Model
M3
Power at 4 ohm
600W x 1ch
Damping Factor
>450 @ 1 ohm
Power at 1 ohm
2400W x 1ch
Power at 4 ohm Mono
600W x 1ch
Dynamic Power
4500W x 1ch
Efficiency thru Output
>85%
Dimensions - mm
540 L x 235 W x 53.4 H
Dimensions - inches
21.25 L x 9.25 W x 2.1 H
Signal to Noise
90 dB
Shipping Weight
24 lbs
You have 1 or 2 10s? you can run 2 dual 2 subs at .5 where the M3 produces more power then the 2500 but at 2 ohms the 2500 will out perform the M3
Sorry. I have 2 10 inch subs and they are dual 2's .
I was also thinking of putting 2 2000 rms Hifonics 1 per sub at 1 ohm each.
Would that be my best and loudest way to go ?
The guy at the shop would trade me the kicker zx2500.1 for either the DD M3 or 2 Hifonics BX2008's I believe are the model.
IM not a fan of the lower line of Hifonics amp if you plan on running your system at 2 ohms then go with the Kicker 2500 if not and want to run at .5 go with the M3
M3 wont do near the power a Kicker 2500 will do at 2 ohms
Kicker 2500 wont play at .5ohms
alright I appreciate your advice.
SWEET06CAMRY
SWEET06CAMRY
SANTA ANA CALIFORNIA
SWEET06CAMRY
vegang
vegang
