PICS COMING SOON
DD M80
Features:
Two Amp Linkable
High level inputs can be fed into RCA's
Terminal block power & speaker connections
Clipping indictator
Thermal protection
Reverse polarity protection
Speaker short protection
Low & High voltage protection
on/off Crossover Selector
Specifications
Input Sensitivity
0.2V - 8V
Variable High Pass Filter
Subsonic Filter
10 Hz - 50 Hz at 24 dB/Oct
Variable Low Pass Filter
20 Hz - 200 Hz at 24dB/Oct
Clipping Display
LED
Tested Voltage
14.4V
Tested THD
1%
Cont Power at 4 ohm
290W x 1ch
Cont Power at 2 ohm
570W x 1ch
Damping Factor
>250 @ 1 ohm
Cont Power at 1 ohm
800W x 1ch
Cont Power at 4 ohm Mono
Cont Power at 3 ohm Mono
Dynamic Power
Efficiency thru Output
>75%
Dimensions - mm
250 L x 247 W x 57.9 H
Signal to Noise
90 dB
Near perfect condition. Used it to power 2 mmats pro p2.5 (also for sale)
$250 shipped.
PICS COMING SOON
DD M80
Features:
Two Amp Linkable
Clipping indictator
Thermal protection
Specifications
Input Sensitivity
0.2V - 8V
Subsonic Filter
Clipping Display
LED
Tested Voltage
14.4V
Tested THD
1%
Cont Power at 4 ohm
290W x 1ch
Cont Power at 2 ohm
570W x 1ch
Damping Factor
>250 @ 1 ohm
Cont Power at 1 ohm
800W x 1ch
Dynamic Power
>75%
Dimensions - mm
Signal to Noise
90 dB
$250 shipped.
PICS COMING SOON
