DD 9500 vs RE XXX
Big-Cat
Registered User
I was just looking at the RE XXX, and i clicked on the T/S Parameters. I don't know much about this stuff, but i think the Xmax is how far the sub cone thing moves up and down, and the measurement is each way, right? and if i'm correct, the more air that's moved from the cone moving more, the more bass is put out?
"XXX 12" Quad 1.2ohm VC Info Sheet
TS Parameters
Fs 34.4Hz
Re 1.17 ohms
Qms 5.19
Qes 0.49
Qts 0.45
Vas 31.6 liters
Sd 480 cm^2
RMS 1600w
Xmax 38mm //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
Dimensions
A 12.5in
B 11.0625in
C 7.5in
D 8.625in
E 4.375in "
and then DD 9500 series, "X-max with 8mm coil in gap - 29 mm each way"
both of these were copies and pasted from the website.
Originally posted by bigbassman the 38mm xmag spec is correct.. but cannot be reached yet.. in the current design of the woofer...
Loyd L.
Hmmm....so what exactly are you saying? That it could reach it, but not until they redesign the woofer? Explain a little further please......
Originally posted by JTz62
Thats cool, that pretty much tells me what I wanted to know. Does this mean you won't be testing it as planned?
yes.. the 12" model should be arriving either late this week.. or early next week..
there is a small discrepency in the xmag value, that I feel is best resolved by RE's themselves.. so feel free to email them on the matter..
Loyd L.
Loyd L.
Did they also tell you 2 weeks to wair for the sub???
Next years will reach 38 mm, and it will also be equiped with XBL2 technology. Same technology as in the Brahma. As of right now, id take the 9500 series, but next year, i dunno. The new XXX will prolly be up to par with the 9900 seires. Not sure yet though.
Originally posted by LateNiteTip Next years will reach 38 mm, and it will also be equiped with XBL2 technology. Same technology as in the Brahma. As of right now, id take the 9500 series, but next year, i dunno. The new XXX will prolly be up to par with the 9900 seires. Not sure yet though.
it's already using xbl2....
Loyd L.
well, that sucks. So now the big xmax question is solved. well what can this year's sub do? **** i hate waiting on this....//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif :crazy: //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Big-Cat
Registered User
Big-Cat
Jupiter, FL
delvryboy
