DD 3515 users...
snb778
blaugh!!!!
I am just trying to find out some input on these subs. I did a search, and there really isnt to much updated info on them.
Im having a hard time figuring out what they are used for...SPL im going to guess, but then whats the diff from the 3515 to the 9515...The power handling specs seem similar...it said like 1600 Continuous...I believe thats what the 9515 is also.....
Anyone use them or hear them before...can you compare them to another top of the line sub on the market....
Im getting a XX Colossus, and I just want to see if these get real loud. I want to build a box like 7 cubes tuned to about 38 Hz if I get them, but im just getting ideas for now.
The 35 has a pretty good overall response. Definately sounds better than the 9500 imo, but thats not to say the 9500 sounds bad. The 3500 is a sql driver, but its been known to put up some good numbers. I was going to get a couple for myself, but backed out at the last moment, but I have heard several of them.
With the right setup You could achieve that easily with 2 15s. They are very underrated, and are easily one of my top pics for someone trying to get loud for a pretty decent price. Since there were no dealers in my area I think they wanted 384 for each 15, which isnt bad.
look nice, do you know the price on them? And in which way are they a step above the 3500's, cause I believe the specs were rated higher on the 3500 series.
So thaaaaaaaaats what those are...ive seen those in someones avatar or something...though they were daytons....i always thought I saw a D on the cone...
Ive had 3515's 9515's and currently have audioque 15hds. Every pair was in the same box 4 cuft per sub tuned to 38hz.
The difference between the 35 and 95 is: If you have less then 1500 rms go with the 35, but if you have 1500+ thats when the 95's shine. the 35s are a more richer sounding then the 95's, but the 9500 w/ 2500-3000 rms will blow you away.
Now came audioque, their specs are similar then a 35 series but they can handle a 2500d for music, where a 3500 could not. In my car and my street setup i prefer the audioques over the 95's. If i had more the 2500 per sub to work with i would go with the 95 since they can handle it better.
The pic you saw on that guys avatar was the HD from AudioQue. The sticker on the cone was an A mated to a Q in Aqua Green/Blue color. I use both brands and with true 3200wrms on a pair, I'd pick the AQ HD15's. Both are killer subs. The HD is a heavier duty sub with more spiders and a larger, stronger motor. You get the same quality either way. The 3515's are, as mentioned above a pissed off daily driver sub, SQL. The company owners of the product brand Rainbow use 2) vented 3512s in their own company SQL demo car. Both will get loud as hell. Both can do 150s with ease if the design homework is put in. It's up to the look you like really when it comes down to it. Price may play a factor as well. Please keep us posted on what you do.
You cant go wrong with either of the 3 choices you have so far. Basically its already been said but i just thought i would chime in for more input and to back up these people. The DD 3500d is, like they said, a very pissed off daily driver sub. Mine get really really loud and there just 10's. I would only go with the DD 95's if you have 2,000+ watts goin to each. They will shine in the correct box and are very very power hungry. It sounds like your best bet would be the AQ HD 15's though b/c there in your price range and are right in between those two, and dont take as much power as the 95's. If you can get a 2500d to each HD 15 and put them in a nice big and well designed box.....Holy shit WATCH OUT!//content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif :naughty: //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif Good Luck!//content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
snb778
blaugh!!!!
snb778
ex. Los Angeles, CA
snb778
