09civic
i emailed them about price quotes but if anyone on here has bought from them...how much are the 2512s new?
Which coil did you get and did you get any options?Went down from when I called them for prices... I just got mine in last night!
Ohh alright how bout the 1512?
I bought mine "used" but pretty much brand new from a member... I called them thou to get prices for recones and a CF dustcap... They told me like 350 IIRC shipped without any options thou?
The 2512 Iam getting will be seeing around 1520 watts from the amp I will be using.What are you guys putting to yours power wise?
Ive got mine on a BXI 2608D at 2ohms it does 1700... I was just wondering how much of that I can safely use... Right now its turned down till it gets broke in a little more but it isnt gettin that loudThe 2512 Iam getting will be seeing around 1520 watts from the amp I will be using.(Bench tested with a 2 ohm resistor and a 50hz test tone so somewhere around that)
I have the 1508 with the options I listed above on 1250rms(tested in the same way)
and I just recently had a 3512 getting around 2200 tested in the same way.
What is your box info-cuft, port area, tuning ect.Ive got mine on a BXI 2608D at 2ohms it does 1700... I was just wondering how much of that I can safely use... Right now its turned down till it gets broke in a little more but it isnt gettin that loud
