DC lvl4 M1 10s
SMS
MA
what can you tell me about a M1 lvl4 with a lvl5 coil? how much power would they take, are they a decent spl and dailly sub? are recone parts hard to get and not overly exspensive?
Do they really need a small ported box- was thinking 3 cubes on a AQ3500 with 15sqin port.
Would the lvl4 motor have enough balls to work the lvl5 recone?
lots of questions, i know
Thanks for any help
I have a m2 lvl4 with lvl4 parts on a saz1500v3, it loves it. as long as the box is built properly and you set the gains correctly you should be fine. My 12 is in 1.5cuft @32hrtz, the lows are almost orgasmic. Some will say to go a little smaller on the enclosure if you plan to run the max/slightly above max, that's rms max, to the sub.
Ok first off the lvl 4 can't use a lvl 5 coil. The lvl 5 coil is 3.5" coil. The lvl 4 is 3". It's a xl coil or upgrade. They can take about 1600 rms daily if this is what you have. The m2 motor is stronger. Also the 1.5 per sub box. Might be too much. Try 1.25 at most
OK, so they must have XL recones. how hard is it to get recones for them now? must you go thru DC? what do they cost?
Thank you
DC Audio - Specifications
SMS
SMS
MA
mylows10
vegang
vegang
