DC lv 3 12 or SA 12??
Well I am bias I have been told but I would get an aq2200 and run 2 sa-12's dual 2 and run that ***** at .5 and it will slam the lows just my experience with sa's thus far.
DC just took off their "specs" page...interesting. I just looked at it earlier today. From what I can remember the lvl3 may give you better low-end, but the SA-12's will definitely have more output ability if you ever want to add more power to the equation(and probably with the power you have as well). The SA-12's can still hold their own down low though.
Also, IIRC the 10" lvl3 is really the only one I'd want to port since the 12" and 15" models look more like sealed box woofers.
heres the specs for the level 3s...
LV3 10" 12" 15"
Mounting Depth 6.25" 6.75" 8"
Mounting Hole Diameter 9.25" 11" 14"
Motor Width 6.5" 6.5" 6.5"
Weight 19.5lbs 20lbs 21lbs
VC Diameter 3" 3" 3"
Displacement .14³ ft .15³ ft .17³ ft
Magnet Weight 17.5lbs 17.5lbs 17.5lbs
Power Handling RMS/Peak 600/1200 600/1200 600/1200
Impedance (Ohm) d2 or d4 d2 or d4 d2 or d4
Sd 487.00 cm² 494.00 cm^² 791.00 cm²
Vas 32.10 L 74.15 L 162.80 L
Cms 9.67e-05 m/N 2.17e-04 m/N 1.86e-04 m/N
Cas 2.29e-07 m^5/N 1.16e-06 m^5/N
Mms 242.06 g 145.73 g 198.55 g
Fs 32.9 Hz 28.3 Hz 26.2 Hz
Bl 22.18 22.18 22.18
Re 5.80 ohm 5.89 ohm 6.10 ohm
Le 5.06 mH 5.06 mH 5.06 mH
Qms 5.21 8.11 8.40
Qes 0.59 0.59 0.71
Qts 0.53 0.55 0.65
Xmax 22.5 mm 22.5 mm 22.5 mm
Sensitivity 84.70 dB 86.40 dB 88.0 dB
Suggested Sealed .65³ ft 1³ ft 2³ ft
Suggested Ported 1³ ft 1.5³ ft 3³ ft
09civic
09civic
Melbourne, FL
09civic
