DC AUDIO XL reviews? TL #'s? PICS? Advice?
  • 4
nissanrider06
VooDoo
1,377
Eagan, MN
Hey all looking for any info you guys got on the DC XL's speciffically the 15"... Rutsy says put em in a 3.5 cube box and i was gonna tune around 33hz for the lows, and then I was going to make a 2.8 cube box with a 8" aero in both boxes tuned to 48 hz in my 2 dr blaze for SPL!
Anyways DC AUDIO XL reviews? TL #'s? PICS? Advice? Speciffically the signle 15" suB!
Check out the "other" forum, they have more detailed easier to find info on the 15. And I think you are goin the wrong way with your box for spl. What rusty recommended to you is perfect for comps. Tuning to 48 would be easy if you made a port insert. Same box, just up the tune.
Also it will handle huge power. I would slap 2500 on it daily and 5k burps.
At the last comp I went to, a guy had a LVL4 XL 12 on a Brutus 2010d and he only did like 139, on music tho...Maybe the install just didnt optimize the sub, but I felt that it should have been louder
Yeah, it is all in box design, you can make almost anything loud. Poor box = poor numbers. You can make a 99z sub hit a 120 in the wrong box, or a 160 in the right box.
^ I didnt realize the XLs could handle so much power. Maybe the Brutus just couldnt push it hard enough. And a box/install issue is always a factor
Yea I am going to just do a straight port to the side and put some extra pieces of wood in there for daily and take them out for comps and I will test maybe bringing it down to 3 cubes but ya i didnt mean 2.3 thanks guys keep em coming, anyone here any or have something to compare them to?
Great subs. I would say stay between 3-3.5 per and you will be fine. As fas as power goes, as much as you can afford. I am currently running an american bass 1100.1 on my 4 and they are fine. Will be adding a second amp soon. They sound amazing.
80a Alt. is your problem....i have a 2017 spark, no way i would go over 1000rms on stock electrical in that thing....and your cap aint doin...
72
if you can read a simplistic book you can follow the directions to put together just fine. Its not rocket science. If you have questions about the...
241
16
656
nissanrider06
VooDoo
nissanrider06
Eagan, MN
nissanrider06
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
