DC Audio 2.0K
Roydon
1. Product: DC Audio 2.0K
2. Specs: The 2.0kw competition series amplifier is a 2,000 watt mono block. It is capable of running up to 16 volts for up to 2,500 watts. It is a linkable amp and designed to run a 1 ohm per amp or 2 ohms when strapped. It comes with a bass knob and a clipping indicator. For power inputs it will accept 0 awg for power and 0 awg for ground.
4 ohm 600W x 1
2 ohm 1,200W x 1
1 ohm 2,000W x 1
Key Features
• 1 ohm stable
• Variable low pass filter
• Variable subsonic filter
• Variable bass boost
• Wired remote control
• Clipping indicator
Recommend for installation
• 1 upgraded battery under the hood
• 1 extra battery in the rear
• Minimum of one 0 awg ran from the front battery to the rear battery
• Upgraded aftermarket alternator
• Dash mounted voltage meter
3. Description/Condition: Like new. I used the amp once at a local show. It was run for probably 2 hours. It did not see under 13v that day. Since then, it has sat in the box.
4. Price: :$375 plus shipping. No trades
5. Pictures:
View attachment 26540470View attachment 26540473View attachment 26540474View attachment 26540472View attachment 26540471View attachment 26540469View attachment 26540475
Roydon
Roydon
Elizabethtown, PA
Roydon
