DBX vs. RL-p **PICS**
jellyfish420
i design boxes .......
i traded my $500 gift certificate for these 2 db extreme soundstreams. they seem to be a little bit beefier than the RL-p's they are ran to a .5 ohm final load. my amp seems to be doing ok, w/ impedance rise i expect it to be around 1ohm. i'll graph it later to make sure. the basket is about 1/8-1/4" bigger on the dbx's. well here's the pics.....
god i hate tilted subs.
its the only way they will fit...the angle on the port hits the frame if i don't.
the dbx's are louder! i've only listened to them for about, maybe 5 minutes...i wanna graph my impedance before i go cranking it up real loud. i'd hate to blow my amp on account of doing something dumb //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
probably later tonite i'll have had a chance to listen to them and i'll let you guys know.
and here is a quick spec comparison
db extreme--------------------RL-p
max 2500w----------------------1200w(?)
rms 1000w-----------------------500w
fs 38.2--------------------------27.487
vas 2.305ft----------------------5.253ft
qms 4.594-----------------------3.728
qes .465-------------------------.508
qts .422--------------------------.447
xmax 14.35mm-----------------24.6
spl 99.9--------------------------89.67 @1watt
rec box
ported
3.3ft^3--------------------------2.5-3.5 ft^3
27.5in^2 port @ 45Hz----------35in^2 port @ 28Hz
sealed
N/A-------------------------------1.5-2.5ft^3
reason they are louder is your gettin more power from the amp.......a good bit more. put em on the same power the RL-p's got and see what happens.
they still get louder;) the first day i didn't even turn it up half way(i wanted to see how the amp would do @ .5ohm) and they were still louder.
the question i got is how come the dbx's w/ 14mm xmax seem to move a hel of alot more than the RL-p's w/ 24mm. and how can the xmax's be that differenet? these are both TC9 motor subs.
P2P versus one way?
those soundstream subs definatly have more xmax than 14mm
P2P versus one way?
one way vs one way //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
maybe measured a diff way? that is the one thing that never made sence about my RL-p's...i have had 4 diff TC9 subs.HCCA 15mm, HYBRID ~17, DBX 14mm, & RL-p 24......
you guys obviouesly dont understand xmax........
im sure the dbx's move more, but not linearly.
xmax isnt an indicator of how loud a sub will get.
jellyfish420
jellyfish420
STL ill side
chubby
