DB Question
Max4hdmatt
i know this might not be a too realistic question. im just looking for an estimate.
how many decibels do you think i will hit with 2 15" L7's in a bow with 8.8 cu ft after port and woofer displacement with 111 sq of port tuned to 35hz. double baffle and about 1000 watts to each sub? im not sure what amp im getting yet. im just curious.
Thanks Matt
It would be much better if you just got it metered. No one will be able to tell you what you are going to hit, too install/vehicle dependent
L7's get loud, i'd say you might be able to get a 150 with those and that power but that would requre a bit of work, So I'll be conservative and say 145-147 if done right
by the way its going in a 96 dodge dakota ext cab. the back seat is coming out.
i figured it wouldnt be to much of an answerable question but i was just curious.
im pretty sure that ill be able to hit 150 no problem. when i get the money im gunna upgrade the alt and put a 2nd battery in.
Running 2kw, I assume daily, you're going to need that alt/battery sooner than you think. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
i wont be driving the truck till summer so i have time to get a bigger alt and another battery. im gunna use my stock battery and buy another one. where would be a good spot to mount the 2nd battery?
Max4hdmatt
Max4hdmatt
Bear, DE
Max4hdmatt
