db Drive pt2000.1D
Nut Hair Trick
Pubes
Item(s) for Sale: Used db Drive pt2000.1D amp that I acquired in a trade a little over a month ago. I hooked it up one time to see if it takes power and it works fine. It's been sitting uninstalled since then because my system build isn't ready.
Item(s) Description/Condition: This amp can be ran on a 18v setup, and it can be ran @.25 daily. Here is a bench test that was done on one of these.
Clamped at using 50hz:
4128 RMS @ .25ohm/14.4v
3168 RMS @ .5ohm/14.4v
2304 RMS @ 1ohm/14.4v
1161 RMS @ 2ohm/14.4v
586 RMS @ 4ohm/14.4
Looks like a sweet amp to me but I need something with a smaller footprint. The only flaw to this particular amp is the plastic feet that come on it. The 2 bottom holes where you mount the amp are snapped off. I'm sure there is a way to get around this if you were to want to mount the amp vertically, because the top holes are just fine.
Price: $300 or trade for AQ2200
Shipping and Miscellaneous Item Information: Buyer pays shipping and paypal fees
I use K3b to rip cds and for converting to any file extension I use Sound Converter or Soundkonverter on a Linux machine but you should be able to...
15
657
I didn’t want to mess with my daughters EV, so I just made a small stand alone with 6x9s. It’s around 75 watts rms and fairly loud actually. Real...
992
Nut Hair Trick
Pubes
Nut Hair Trick
Arlington, Tn
Nut Hair Trick
    May 16, 2024
    May 16, 2024
