DAYTON RSS315HF-4 vs Image Dynamics ID12 v.3 D2
the ID looks to have a lower FS and higher Xmax.
i've personally owned an iD12 and it sounded great ported. Never missed a beat either. The output wasn't bad, too
The 12HF is an excellent sealed box, ultra-low inductance, SQ sub with some good bottom end. As noted by JB, Xmax isn't the most out there... 400W in ~1.5 cu ft sealed will put you at excursion limits. If you were looking to go ported, the 12HO would be a better choice (or the ID sub).
Im going for sealed box. So which sub is better for sealed box ? ID or Dayton ?
The Dayton sub is one of the most accurate, musical subs I've ever heard... and I listen to a 12HF every day.
But, there is no denying that the ID has the total displacement advantage, and in a sealed box, more displacement = more output. Of course that doesn't really matter if you aren't running enough power to get the ID to Xmax.
If you plan to run ~400W @ 4-ohms, then you really can't go wrong with either one -- in that case, box size, frq response, and output will be close to the same. Go with whichever one you can get for less money (shipping included).
magX
magX
AMC, IL
TeoTorriatte
michigan born
    May 14, 2026
michigan born
    May 14, 2026
