Sold Dayton RS-180 Pair
RAM_Designs
SketchUp Master
I'm selling my trusty Dayton RS-180's that are in mint condition. I cut the metal tabs off the side opposite of the terminals in order to fit them in my doors easily. It's just a tab where the terminals would connect to had they been put on that side(easy to see in the pics).
$75 shipped with a MO, $77 with paypal.
I currently have polk momo's in my doors would i just remove the mid speakers and replace them with theses and use the polks crossover?
Depends on what the polk crossover was designed for. Here's some things you need to consider.
1) Make sure the ohm load the crossover was designed for matches the new mids. If they're different, then the crossover points will change a good bit.
2) The actual corssover point. Most comp sets use a 12db/oct crossover at ~3khz...these mids just won't work with that. 12db/oct at 2khz or 24db/oct at 2.5khz is as high as I would go with these.
3) Matching sensitivity. Make sure that the new mids are fairly close to the sensitivity of the current tweets you're using. Unless you have a detailed EQ that can attentuate either the mids or tweets completely, be sure to have the sensitivity within 1-2db of each other(also be sure it's being measured the same way).
RAM_Designs
SketchUp Master
RAM_Designs
Rockwall, TX
RAM_Designs
