well actually i think ill be savin money cuz a pair of the mids/tweets is 80 + shipping and then whatever the x-overs cost.
You could highpass the tweeters fine with the xover then.....but you wouldn't be able to bandpass the mids.alright i was just one orion's website and found out that the 4 speaker channels have a low pass/high pass each from 20 to 3000hz, so does this mean i dont need an external one cuz i want my mids to be from ~120hz to ~2.5khz and my tweets to from ~2.5khz up. and would 16 gauge speaker wire be alright for my subs/speakers or should i go lower?
Yes, each channel has it's own highpass and lowpass. But you can not highpass AND lowpass the same channel at the same time, as would be needed for a mid.well then why wont i be able to do that, each channel has its own high pass and low pass on it. sorry if im frustrating you i just dont get why it wont work.
WHAT??? have you wired an amp before? You do not want to bridge a channel to run both of your mids anyway, as then you will lose stereo sound...ok so if i got one of these for each mid
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=266-170
would i be able to use the amp low pass and the external hi pass?
or, could i bridge both mids on to one channel, then have the lpf set on one of the two, then the hpf on the other?
