DA D5 1200.1 Question
Alpine CDA-9815
I've noticed this thing has 2 sets of outputs for going to the sub. Now it says that "the two sets of outputs are paralleled inside the amp to a single channel. this gives you the ease during the installation of multiple voice coils woofers.".
The sub is a dual 2 ohm, so basically I can just run one output to each of the voice coils and get 1 ohm, correct? However I don't want to drill the box again for another set of wires, so I should just be able to run one set of wires from the amp then connect it parallel as I have it now and I will still get 1 ohm?
yes that will work...run two speaker wires to the sub from the amp...It will see 1ohm load
Aye. However I only want to run 1 and then parallel the VC's from inside the box as it is now. Would that work just the same or do I have to run two?
Alpine CDA-9815
Alpine CDA-9815
BFE
Alpine CDA-9815
