CVR's not getting loud
DaRevrin
I have 2 kicker cvr 10s in .6cu ft a piece. Really small sealed box, they are not getting loud and they arent sounding to good either. My infinity kappa perfects sounded way better and louder.
Id like something that will be a lot louder in a small sealed box with an excursion of 14mm or they will hit the bak of my seat.
somethin around 350 to 400 rms
mounting depth less then 6in
excursion of less than 14mm
works well in small enclosure wired at 2ohms
What would be the loudest sub i can get that would work in this application.
price limit 400 for both and under
Uh no on the jl 10w7 way to much excursion and to much money, and thats the tough part by the look of it those q power subs had to much excursion that will hit the back of my seats.
I kno i wired them correctly. Phase? I kinda think i did somethin wrong cuz i heard they were supposed to get much louder than the kappa perfects were. The gains are around half way.
amp infinity reference 611a mono
I beat 4 CVR 15's in a wall with 1 L7 by about 4 db's. They're not "loud" subs, imo.
Loud and a single sealed sub usually don't go well together. Get more power and a low tuned box and you'd probably be happier. Subs aren't magical.
I cant get the boxes any bigger and the 2 boxes are the only ones that will fit behind my seats. There is no room back there. But since the cvr's arent working to well which 2 tens will work best with the room i have? I want loud.
excursion of less than 14mm or less
works well in small enclosure .6cu ft gona be wired at 2 ohms off of infinity reference 611a mono amplifier.
RSd10 or RSd12?
Stuff a bunch of loose polyfil in the box. That'll make the setup behave as if there is more room than there really is.
DaRevrin
DaRevrin
Memphis, TN
DaRevrin
