Cutsheet plz...
not sure if ya got one yet but if you are having homedepot do it they do not need pictures of what the wood will look like cut, they only need the dimensions, and the amount of each peice that you need.
//content.invisioncic.com/y282845/emoticons/idea.gif.5acb6a39a9b92425414c316dda202bad.gif Take a piece of paper. Draw a rectangle 8" x 4" each inch = a foot. Now you have a scaled down template to work from. Use a pencil and keep trying out different cuts until you get what you need.
Really man. You disserve a little flaming for not being able to think of that yourself.
Only let Home depot cut it to fit in your vehicle. They do not account for the blades thickness when cutting and there track is normally crooked
nah man, i just had them cut me some wood, i gave em the dimensions of all the peices and they cut they wood how i told em too. but i suppose it could vary depended on where you are.
How accurate did the cuts end up being?
E-tough? No, I just cannot understand how someone drawing a square with numbers around it will help you versus you doing it yourself.
Well the main reason I asked for atleast a decent cutsheet was because I wasn't sure if they would take some haggard peice of paper with squares drawn on it. But apperrantly all they need are the dimensions. Also, The cutsheet will give some nice size scraps left over. Amp rack here I come!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
if no one helped you out yet, here yah go..
Omg, i wish it was that easy. I gave the guy the dimensions of each wood i need cut and dude took an hour to just draw up a plan. He took a very long time just planning it out on a piece of paper with his pen. So i had this problem and came up with a solution. ^^ as you can see theres a cut list layout right there. :)
well i told the guy if he messed it up he could buy the mdf and i would go somewhere else and do it my self, so he cut it right //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
lol, you threaten the innocent man. //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
LuNaTiC
18 to make up for below.
LuNaTiC
MA
LuNaTiC
