Cutsheet Help? 1st box build
britdevine
This is my first box and am unsure how to make a cut sheet.
2 10's will be going in firing forward in a crx, port going out the back of box
Box needs to be 21.5 wide on the front face internally and internally be 12.5 tall so I can screw in my 8' areoport.
It also needs to be 11 long internally.
Can anyone help?
Thank you, I did check the ground and and fuse holder wires and everthing is fine. All I did was swap amps and the previous Alpine pdx sounded...
49
575
575
britdevine
britdevine
Central NY
on1wheel01
