giantgloworm
Hey looking into buying a custom TC Sound driver. It has dual 3.5vc's and the specs are
T/S's are as follows with the coils in series:
Re: 6.14
Fs: 24.5
Qms: 5.64
Qes: .362
Qts: .34
Le: 5.56
Sd: 72965 mm^2
Vas: 138 liters
BL: 24.35
Mms: 226.56
RMS: 6.2
Sensitivity: 89 dB
Can you guys give me some enclosure ideas. It will be getting just under 700watts. I listen to just about every thing so it needs to be a good all around fr. responce. Would like to tune the port to around 25hz. Will be using a 48db subsonic filter at the tuning freq. So shouldn't have to worry about it unloading. This will be the first ported box for me. Going to try and start out right. I normally like larger sealed enclosure, but using smaller amps. I think ported will be the way to go. Thanks for any help!!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Re: 6.14
Fs: 24.5
Qms: 5.64
Qes: .362
Qts: .34
Le: 5.56
Sd: 72965 mm^2
Vas: 138 liters
BL: 24.35
Mms: 226.56
RMS: 6.2
Sensitivity: 89 dB
