Custom door pods and more.
They're done... for now!
I'm still deciding on what I want to run. I need to make up my mind so I can order everything tonight.
The plan is to switch to bucket seats and run a single 10 behind the passenger seat (external aero port on the passenger side (running behind the amp rack.)
I'll post a diagram here in a bit.
Howd you attach the long end to the door?
I put 6 tee nuts on each pod. If you look in the first couple of pictures you see 6 random pieces of tape, under each piece of tape is a tee nut. Once I was done I just bolted them right on the back of the door panel.
I wanted to be able to remove and install them as much as I wanted without having a ton of screw holes.
mobileaudio219
mobileaudio219
Central, Missouri
mobileaudio219
