Custom Crossovers
I'd just go ahead and buy a DCX2496, they will be in stock at the end of this month and theyre only $250. Theyve got 4-way xovers, 48dB slopes, and all the equalization you'll ever need.
It's kind of upper-end isn't it? I don't know if I could even figure out out to use all the features, heh.
I was thinking of doing a TMW tower powered by a Behringer A500. That is why I needed the crossovers. I don't think this would really help because it would require more than one amp.
You heat both, the solder bonds to the wire.
That looks pretty easy to solder.
I just priced the parts and its kind of expensive. Much more expensive than I thought anyways.
I figure I can buy the prefab for $45 and not worry about it. I only really go DIY if you can improve cost/performance.
I actually drew my own possible crossover and I will post pics later.
Here is what I was looking at using that crossover from Parts Express
Crossover 260-150 x2
Woofer 295-366 x4
Mids 264-422 x2 (need much better reccomendation here, something good from 375-3000hz
tweeter 264-578 x2
all powered by a Behringer A500
I can get all this from PE for $571.53 shipped.
You think that is a better plan than trying to pay someone to build the crossover for me? Would someone do it for less than $50? It seems it cost that much in parts alone.
Flipx99
Violator of Terms
Flipx99
Building 100
Flipx99
