Custom Av.2 15"
*Ace*
Item(s) for Trade:
Custom 15" Av.2 Subwoofer
Cosmetically = 8/10
Mechanically = 10/10
Visually the motor has some small scratches from previous owner and the glue job could have been a bit prettier (this was my first custom build and first time using CA glue lol). Just a few areas received a little too much activator and caused the surface of the CA glue to bubble and whiten a bit. But all the joints are strong and I tested this guy for probably an hour in my car. It was free air and was hooked up to my Audioque 1200 at 1 ohm with no issues at all.
It uses an Elemental Designs AV.2 motor with a 3" 4 layer copper D2 voice coil, TC Sounds 15" Ti Basket, stacked 10" TC spiders with dual sewn on leads, Sundown ZV.3 15" Cone/Surround, and a 5.9" CF dustcap.
Looking to trade for:
Let me know what you got. Really interested in JL13W7, JL Slash 1000/1, Sub motors/parts
How tall is the winding in relation to the top plate?
WW is 2.29", Top Plate is 2". Amount of coil sticking above the top plate is ~.145". It's probably offset a little low though, because it's pretty hard to eye it and get it exactly .145" above the top plate lol.
Replied
trade for a JBL GTI MKII 15? similar to a w7, SQL monster sub
Very tempting, but no thanks. Trunks not big enough to fit a 15" the way I would like //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
If it helps any, they prefer really small enclosures, it's rated at 1k but since you'd be giving it the power of the AQ1200, it really wouldn't need much space at all.. Probably around 2.6 net
I have enough volume to work with, just not enough height in my trunk. Plus the JBL is dual 6 ohm so it would only see a 3 ohm load from my amplifier //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Ahhh I gotcha, well if you did the baffle at, say a 45 degree angle it'd probably fit perfectly. No?:)
Alpine PDX or a JL slash 1k would be nice
*Ace*
*Ace*
Las Vegas, NV
04murdalanche
