Crunk Times, My friend.....Crunk Times
Drank... a lot. Went out to a lot of bars, mingled with some hot lady friends (a lot to choose from at IU), saw a great performance from a somewhat local band, topped the night off with a J.J. Gargantuan from Jimmy John's. Went home around 3:30, I think I fell asleep in the lounge chair on the porch. Time of sleep is unknown since I woke up in my bed this morning and don't remember transferring my sleeping locations. Woke up with a very slight hangover, which was cured by a bottle of water. Nothing too grand, but crunktastic to say the least.
Maybe the women you see and date are all perfect women, unfortunately, in the cases I have seen, the women contribute just as much to these violent episodes as the men.
For the record, I do not see or date women.
I am happily married, so for me it is woman.
//content.invisioncic.com/y282845/emoticons/bigwave.gif.16324171cad2db62cf4f16568b038478.gif Hey honey!
today i learned that if you want to add an aftermarket four channel in a 2000 beetle while retaining the factory HU to have to present a resistive load (4ohm) to each of the four channels of out put from the radio in order to get them to function other wise you will be left with a correctly wired system that does not work
when i first fired it all up i got no ouput from the radio which i tested with a meter....then i used a test speaker and everything on the channel i tested on began to play thats when it clicked that you must present a 4ohm load across each separate channel to get the aftermarket amp to receive and signal...and the only resistors i had were 2 ohm resistors so there are 8 resistors sitting behind that radio right now
bdawson72
Finally Has Bass Again
bdawson72
434/804, Virginia 15's:Yezzir
▼)Ñ╩fZΣµ&
