Crunk Times, My friend.....Crunk Times
I want to know what the **** is wrong with my pool.
Why the water turned green after a big rain, but their is no algae whatsoever. Why it won't settle to the bottom and vacuum out. Why 5 bags of shock didn't do a dam thing to it.
I **** at keeping up a pool.
The first summer/fall I lived here the pool got clear easily, and stayed that way till closing time. All I had to do was vacuum it every once in a while.
What were your CL levels before the storm?
Go get some algicide and clarifier. Backflush your filter after a day. Then during storms put your cover over the pool if you have one and run your pump. If you don't have a cover, get one.
I don't have problems in storms, but my dad has similar problems with his above ground in Indiana. He also does a mini shocking directly after a good storm.
Also control your PH level. If it is too high then chlorine and shock is ineffective.
Inground?
Yes.
How'd he do that?
Lots of digging, ever see that pic of him ith the bobcat(excavator)?
I'd rather pay sycko or one of his relatives, than building the pool on my own.
Sounds like a plan, you can pay them with churros.
I want to know what the **** is wrong with my pool. Why the water turned green after a big rain, but their is no algae whatsoever. Why it won't settle to the bottom and vacuum out. Why 5 bags of shock didn't do a dam thing to it.
I told you to use bleach, it's stronger and cheaper! Lot's of bleach.
Also get your water tested for copper, I think you have copper in it and it's having a reaction with the chlorine.
bdawson72
Finally Has Bass Again
bdawson72
434/804, Virginia 15's:Yezzir
▼)Ñ╩fZΣµ&
