joker4096
F'n Loud
Ok, so i have had this amp for over a year, it use to run fine. First setup was 2 RE audio sx dual 4 ohms and they ran fine. Now I have a soundstream tarantula t5 12 dual 2 ohm. I was running a 60 amp fuse agu on the power line for a while and it started to pop them. 2 in less than a week. the amp has 2 50 amp fuses so i know i was under doing it with the inline fuse. my remote wire had a tear in it causing the system to come on and off a lot. got that fixed and now the amp goes into protect every time i turn it on. the power led turns on and immediately goes to protect. i unhooked the rca, and speaker wires and it does the same. I opened the amp and nothing looked burned out or anything. anyone know how to diagnose this? If you can repair it i will pay you im in the seattle, wa area
