crunch gp 3k pro vs opti 4000d
You'd be hard pressed to find someone on here that's run both of these amps and can give an honest opinion. That being said, they're both great amps, I've been running that Crunch amp for some time now and like it. They bench tested it on one of the other forums and got over 4kw out of it @ 16V IIRC
Because when it states on the box, 2000 watts!!!, and when I opened it up and looked at the fusing and manual states 300watt rms, that's a metric assload of over rating. FWIW, it was a vibe.
yeah lanzar tends to over rate just a tad they make good subs for there money but still over rated on both subs and amp definitely keep the crunch
Lanzar Opti line is a whole different ballgame than their other stuff. Check ampguts, you'll see Opti 4000D is same board as Soundstream 6500. Both of which I've seen good reports about.
What Spls said.
Comparing your experience with a $100 "2000w" Vibe to a $1000 opti4000d is like saying the new Camaro's **** because you drove an Aveo and it wasn't fast.
jdmferio13
feayfm
jdmferio13
Central,PA
kr15
