Crossover Help
I Need a 3 way passive crossover to power these speaker in a cabinet speaker box any recommendations
Two 18 Sound 12MB1000 Specs:Midrange/Midbass
Nominal Diameter 300 mm (12 in)
Rated Impedance 8 Ohm
AES Power 600 W
Program Power 800 W
Peak Power 1600 W
Sensitivity 102 dB
Frequency Range 80 ÷ 3500 Hz
Power Compression @-10dB 0,5 dB
Power Compression @-3dB 1,5 dB
Power Compression @Full Power 2,1 dB
Max Recomm. Frequency 2500 Hz
Two 18 Sound HD2080T Driver Specs:
Throat Diameter 50 mm (2 in)
DC Resistance 6,2 Ohm
Minimum Impedance 8 Ohm at 3500Hz
AES Power 100W above 1,2 kHz
Program Power 200W above 1,2 kHz
Sensitivity 109 dB
Frequency Range 500Hz ÷ 20kHz
Recomm. Over Frequency above 800Hz (12dB/oct slope)
Three Beyma CP22 Tweeters Specs:
Impedance 8 ohms
Minimum Impedance 8.5 ohms @ 9.0 khz
D.C. Resistance 6.1 ohms
AES Power Rating 25 Watts
Program Power 50 Watts
Sensitivity (1W/1m) 107dB SPL
Frequency Response 4kHz - 20kHz
Recommended Crossover 5.0 kHz or higher
Dispersion (H x V) 40° Conical
Voice Coil Diameter 1.5" / 37.6mm
Magnetic Assembly Weight 2.64 lb. / 1.2 kg.
Flux Density 1.55T
BL Factor 5.2 N/A
DrzCrazyNigga
DrzCrazyNigga
Milltown NJ
Papermaker85
