crossfire vr2000d wiring
tsupra98
ok so the vr2000d has two poss outputs and two neg outputs. and i've been told it's one channel on the inside. so that being said i'm wiring my two L7's which are both d2 voice coils to two ohms. right now i have it wired like you'd see off most charts. but if i wire the subs one at a time to where it's 4 ohms and connect one sub to one set of poss and neg and do the exact same to the other will the amp read 2 ohms inside?
i hope i worded that right and help would sure be appreciated
as far as the pos and neg speaker outputs on the amp...you can use both or just one set...its all the same...just don't accidentally use ++ or - - together going to the speaker...or you'll have probs...
ok so if i do it that way the amp will still get a 2 ohm load?
tsupra98
tsupra98
waco, tx
tsupra98
