Crappy Amp Installation Cont...
defensa24
PT Cruizer
Harness on the left goes to the HU and the harness on the right comes from the dashboard...
This is the solid blue cable coming from the harness going to the HU...Is this the right cable to turn on the amp...?
This is the blue and white cable coming from the dashboard...
The remote turn on cable coming from the amp
My crappy HU...
So out of the two cables...which one is the right remote turn on to connect to the one coming from the amp?
Ok...Have a good feeling about this...BUT...I think I already tried that one...I mean...Its common sense to hook it up to that cable first...and the amp still didnt turn on.
here's my crappy install
I'm sure you got shit about that cap, but the install doesn't look that bad. Hyperflex wire, wires are run clean.
Blue with white stripe is more than likely the remote. split that one between the 2 amps once you run it from the back of the HU
blue/white is antenna, and on the factory harness.
Judging by the fact that the remote wire is exposed like that, it could have easily grounded and burnt the HU
ok guys...the pic with the two amps is NOT mine...
its some dude's showing off...
My connection problem is that I dont know which wire to connect the remote turn on lead coming from the amp...I only have one amp...
Nope...my HU still turns on...
Yes, the blue is the remote. Make sure all the connections are solid, especially where the black wires connect.
Just run the remote to the amp. You can just run a jumper from the one amps remote hookup to the other amps remote hookup.
defensa24
PT Cruizer
defensa24
Asheboro, NC
Anybody Killa
