coustic amp problems
XX95DSMXX
alright i have a coustic amp600 here are some specs
2 Channels
150 Watt x 2 at 2 Ohm
75 Watt x 2 at 4 Ohm
300 Watt x 1 at 4 Ohm Bridged
Input 5 V Maximum Input Signal
Adjustable HP/LP Crossover - 40Hz - 350Hz, 12dB/oct
ive got 4G power and ground wire as it recomends and it has 13.4v going to the amp
i have the speakers bridged to 4ohms
well here are the problems well the amp doesnt sound good unless the gain and stuff is up pretty high...iv used the gain setting tutorial and everything
well after i set the amp up to where i want it and listen to it for about 1/2 hour it starts overheating and shutting off.
another thing i noticed and not sure if its relevant but when the bass hits the power to the amp drops some like the lowest ive seen is like a 13.1v
just hoping to figure out why the amp is doing this....i called coustic and they tell me something is wrong with the amp so i got a replacement and same thing is still happening
does anyone here have suggestions???
the speakers are 2 12" kicker compVR dual 4ohm wired so each sub is 8ohms
XX95DSMXX
XX95DSMXX
mannington wv
XX95DSMXX
