could i build this slanted?
Sure thing:D Just make sure theres enough mounting depth for your sub. The box shape doesn't make much differance as long as you get the right amount of airspace
im trying to fit 3 cu ft for the L5 in a single cab f-150. Kicker manual says you may put polyfill with mesh grill by the port. Whats this do?
polyfill will fool your subs into thinking that it's in a larger chamber than it really is...
but it can also upset your port tuning, as the port is designed for that specific volume...
can't go wrong with lots of polyfill in sealed chambers, but for ports, I guess you would need a very good program to determine the exact amount of polyfill to stuff inside the box...
good luck with it!~
16
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
911
Currently Audison amps 500.1 and 4.300 with kappa 90csx 6x9 component set. Pair of morel 6.5 rear and a single 10” alpine type R.
982
MaDroX420
MaDroX420
Albany, La
MaDroX420
    May 24, 2024
    May 23, 2024
