could an amps internal HPF be bad??
bobo244
I am getting terrible output from my system, and I know its not my subs and Im pretty sure it has nothing to do with my box.
I just got a refurb opti2000d and im getting NO low bass at all and huge peaks when songs play. Im thinking its something with the amp???
are you running 2 subs?
im runnign the setup in my sig..
there is no on/off for the sub sonic, its set at the lowest it goes, 15hz.
The LPF is at about 100hz. I got the subs wired to .67 ohms.
How would the ohm load affect the requency response??
The hpf is at about 100hz. I got the subs wired to .67 ohms.
double check tthe + and - of your subs. I had a very similar issue to your description and when I switched one sub's + and - around it start sounding normal... they cancel eachother out or somethin...
bobo244
bobo244
Miami Florida
PatFitz9
