Controlling Subs
Ok that's why I want to filter out the lows.
So i checked my HU and that HPF only affects the door speakers and also only goes down to 50hz.
Is there an external subsonic or High pass filter I can install between the amp and headunit?
well hell, there must be a cheaper alternative. there's no way to setup an external subsonic filter?
Yes, they make external crossovers for pre-amp (RCA) level signals. You would just need one that can be set to high pass for a very low frequency cutoff.
the music culprit is stuff like bass nectar, different rap from lil jon and others then some steve meade reccomendations and trap music
the box is about 35 hz
also say i pickup a 6000 watt amp, can i only use like 3000 max watts of that amp for a more all around steady clean sound?
You can't go from a ~1,200W amp to over twice the power without adding expensive electrical upgrades. It's also going to destroy your sub that much faster below your port tuning frequency. If bass below 30 Hz is super critical for your enjoyment you need a new enclosure, and possibly new subwoofers. The flip side to this is you run out of "steam" at higher bass notes, meaning your speakers are expected to do a lot more work to fill in the gap.
bernouski
bernouski
temecula, CA
trumpet
