Continuation to my magnet off speaker tread.
miked56
First of all pics at bottom so I don't get banned //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
When I took the rubber off the magnet there were no bolt heads so I assume it was not attached with bolts. I have a Q into Focal to confirm this but the US operation does not usually seem very responsive to customers //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Several people spoke of CA glue. What is that? Secondly, will I need to find a way to hold pressure between the magnet and base plate while the glue is curing?
ca glue is superglue, with an accelerator. I personally would use 2 minute epoxy, and hold it on there with my hand while playing it so that you know your not gonna get any bad noises when it finishes.
also the pics or ban thing is just a joke, incase you havent figured that out yet
lay the speaker cone side down and the voice coil standing straight up.
get some extra strenght 2 part epoxy, found at home depot or an auto parts.
something like this
get a 20-30 minute setting one.
mix up the epoxy then pour a bead of the glue close to the outer rim of the top plate(the plate still on the basket)
after you set the glue you sit the magnet/motor on. align it as best as you can. witht he weight of the magnet it should be suffecient to clamp itself down. if you want you can sit something on top of the magnet for additional weight. let it sit for 6-12 hours.
miked56
miked56
Alexandria, VA
miked56
